blazer rpm surges
Old Mar 10, 2020 | 07:53 PM
davalex's Avatar
davalex is on a distinguished road
Default blazer rpm surges
99 blazer 4.3 230,000 miles.while driving engine surges 200 to 500 rpm then drops down to where it was then does it again does not always do it.some times for a few minutes other times for the entire trip.help
Old Mar 12, 2020 | 01:24 PM
Mods's Avatar
is the motor doing it or just the tach. if its just the tach thats a sure sign of the ICM giving it up. very simple and cheap fix.
Old Mar 12, 2020 | 07:37 PM
davalex's Avatar
motor as well as tach
Old Mar 12, 2020 | 09:18 PM
Mods's Avatar
..thats very strange, done a fuel pressure and leakdown test? wondering if the regulator is starting to have intermitted leaks and pouring raw gas into the intake at random. may also be TPS related so if you have the means pickup a cheapo scanner that can read live data and see what the TPS reading is doing when surging.
Old Mar 13, 2020 | 04:02 PM
davalex's Avatar
I will scan it thanks for your help
Old Mar 15, 2020 | 11:31 AM
LesMyer's Avatar
Sounds like TCC operating normally. Bet it doesn't do it below 45mph or if you drive in 3rd gear.
Old Mar 16, 2020 | 07:57 PM
davalex's Avatar
I have not tried just driving in 3rd. gear .it was only doing it below 2000rpm but going home it started to do it just above 2k rpm but stopped and ran like it was new.
StarScreamin
Apr 2, 2018 11:07 AM
Bagherra
Nov 10, 2017 09:23 AM
jdog2pt0
Aug 19, 2013 05:11 PM
antz2009
Dec 17, 2012 01:21 AM
renskee1sfk
May 11, 2008 02:45 AM
