Blazer Slight Miss at Idle
Anyone else have a problem with their blazer having a slight miss at idle? I just had the heads resurfaced and a valve job. Just got the engine back together today and the slight miss is still there. Maybe it's an urban myth, but I always heard if you held a dollar bill up to the tailpipe and it blew and sucked it back in, you have a burnt valve. Well, I had the problem before sending the heads to the machine shop and I still have it after the valve job. What gives with the miss at idle? What else can cause those symptoms?
I like the Chevron Techron Fuel System Treatment Plus, but I use it more as a preventative measure than a "use it cause I'm having problems" type of thing. There are some professional kits that run the engine off of a pressurized can of cleaner that connects up to the fuel pressure test port. It requires that the fuel pump be disabled (remove the fuse and/or relay). This is a more intense manner of cleaning and usually does quite well.
dabearsjjk
Dec 21, 2014 06:52 AM
ussexplorer
Sep 27, 2013 03:38 PM
mrgreazm0nkey
Sep 19, 2010 11:13 AM
RobMacLin
Oct 18, 2009 09:23 AM
