Blazer start fine when cold but then once warm can't get it to start. . . help?
Old Jan 22, 2015 | 04:06 AM
djmehkae's Avatar
djmehkae is on a distinguished road
Default Blazer start fine when cold but then once warm can't get it to start. . . help?
Ok, so the diagnostics said the mass flow air sensor was going bad but I've been driving it anyway without any problems, now, if it's cold it'll start in a snap but once I've run it and the enginen warms up and then turned it off, it won't start. Got new fuel filter but was wondering if mass air flow sensors playing apart in the problem althoughlike I said. . . it's been running fine with the light on in the dashboard about checking engine ( i.e. mass flow air sensor) Could that be causing it now to not start once it's warm? Or is this something altogether new. Anybody anybody????. . . . .plz help thanks
Old Jan 25, 2015 | 10:53 AM
Gregg64's Avatar
Gregg64 is on a distinguished road
It is going to start giving you a fuel lean\ rich mixture problem . You need to check your codes and see what else is coming up. could be a few different issues but you need to take care of what ever is registered first .
Old Nov 7, 2017 | 08:07 PM
Christopher Schrimsher's Avatar
Christopher Schrimsher is on a distinguished road
I have a 2000 s10 Xtreme 4.3 5speed.. it seems to hesitate once warmed up give it gas and it jumps but cold not so much any idea what causes this
Old Nov 7, 2017 | 08:08 PM
Has new throttle position sensor ignition
BlazingChevy
May 31, 2013 12:27 PM
Bill Gillin
Dec 23, 2012 04:56 PM
Brock Samson
Jul 24, 2011 08:57 AM
filthy sanches
Oct 29, 2009 05:52 PM
Inferno
Oct 22, 2006 08:56 PM
