bolts for lower intake gasket
Old Mar 12, 2007 | 01:33 AM
uri's Avatar
uri
uri is an unknown quantity at this point
Default bolts for lower intake gasket
hey guys, Greg here was doin my lower int. gaskets and forgot what bolts go where wondering if any of you could help . by bolts i mean all of them. pictorials would help alot. thanx for the help
Gregster
im out
Old Mar 12, 2007 | 02:26 AM
aspenpup's Avatar
aspenpup is an unknown quantity at this point
Default RE: bolts for lower intake gasket
Just so happens that I have my '99 disassembled. The top bolts looked like I was going to forget their location so I stuck them into cardboard. Any nuts from those posts I put them on. At least you have an idea about this group. The bottom of the picture is the front of the engine.
The lower 8 bolts are all the same size so I figure you must know where those go. Any others locations you need info? (Assuming you are working on a 4.3)
I have a series of pictures that I took while disassembling everything. I can e-mail you those if you think that might help.
[IMG]local://upfiles/793/DB28A14A103947008D8A7100971A878B.jpg[/IMG]
Old Apr 5, 2007 | 09:33 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
I don't recall any differences in the bolts that hold the metal manifold on. Just make darn sure that you have the heads and manifold squeaky clean, and that the RTV sealer used across the end seals goes at least 1/2" up on the gaskets at each side. Set the manifold IN PLACE without moving it around, and torque carefully.
My write-up on this is in the DIY section.
Old Apr 5, 2007 | 11:05 PM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
dam that was a lucky break for you there
castiglian
Sep 13, 2014 04:39 AM
Melrock83
Jul 3, 2012 06:51 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
not_only
Oct 23, 2010 04:48 AM
Nativepenguin
Jan 4, 2008 07:40 PM
