Break booster
Old Feb 22, 2018 | 03:34 PM
Dillion's Avatar
Dillion is on a distinguished road
Default Break booster
My girlfriends 96 break booster has been going out for a while today she was in traffic and when she accelerated is wasn't fully going. Then all her gages started going all over and her car died. She said there was smoke coming from where the booster is and when I try to start it it will start to go then die the first time then just click after that could it be something with the vaccume
Old Feb 22, 2018 | 07:02 PM
If it is a vacuum problem, you should be able to plug the hose that that supplies the vacuum to the booster so that the engine doesn't try to run with a big vacuum leak. If it starts and runs fine, then likely you have isolated the problem. Can't say I'd advise driving without the booster working though.
Old Feb 22, 2018 | 08:00 PM
odat's Avatar
vacuum leak at the booster or just a vacuum leak period would not cause gauges to flutter, make smoke or the just click on trying to start - sounds like you prob have a short in the wiring
whistle
Nov 20, 2006 12:42 PM
consernedguy
Nov 6, 2006 11:19 PM
JCG1
Suspension Tech
Sep 19, 2006 02:07 PM
88s10Blazer
Engine & Internal
Jun 23, 2006 01:39 AM
khalid_20879
Jan 3, 2006 01:00 PM
