Broke Piston and Rod
Old Feb 17, 2010 | 10:58 PM
K5corey's Avatar
K5corey is on a distinguished road
Default Broke Piston and Rod
I was working on my 84 blazer today getting ready to remove the motor and I ran into a problem. i have a a broken rod and piston and the crank is ceased up. i cant get to 2 of the 3 bolts that connect the fly wheel to the torque converter.
Anybody have an idea how i could free the crank?
Also does anyone know what would cause a piston to break apart?
Old Feb 17, 2010 | 11:47 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
pull the pan and unbolt the rod?
Old Feb 18, 2010 | 07:38 PM
abig84's Avatar
if its a 2wd you cant drop the pan cause of that stupid crossmember there maybe if theres enough room, cut the pan off . one way i can think of is pulling the tranmission and engine as a unit then just pull the trans off when its outside the truck leaving the torque converter attached then you can get at all the bolts.
Klturi421
Aug 2, 2011 07:21 PM
WLB
Engine & Internal
Dec 13, 2009 04:02 PM
toaks1
Sep 10, 2009 04:26 PM
lakeblazer91
Feb 18, 2009 10:06 AM
quinn1991
Tires and Wheels
Dec 28, 2008 02:41 AM
