A/C Compressor
Old Jul 30, 2017 | 11:20 PM
ChevyChrissy76's Avatar
ChevyChrissy76 is on a distinguished road
Default A/C Compressor
I have a 2003 Chevrolet Blazer LS 4WD 4.7.
My ac compressor siezed up on me and I need a little bit of info. It started up just fine this morning but now the pully is not moving, it's shredding my belt and my engine cranks like it's siezed up itself. I'm starting with the compressor and plan to go on from there if it doesn't fix it.
My questions are these:
1. How do I discharge the AC system?
2. What should I look for in a new compressor (ie. Prelubed, needed fluids besides recharge)?
3. Do I need to flush or replace anything else?
This is my first AC compressor replacement and I want to make sure I get it right.
Thanks in advance!
Old Jul 31, 2017 | 02:59 PM
LesMyer's Avatar
Thanks in advance!
If the belt is shredding with the A/C turned off then the compressor itself may not be at fault. There is a bearing there that works when compressor is turned off, and this is the best case scenario for you.
On the other hand.... when compressors shell out / lock up, they distribute metal particles throughout the A/C system. Definitely should be completely flushed with solvent, accumulator and orifice replaced before installing a new compressor. Then pumped down on a vacuum pump to evaporate all flushing solvent and filled in the correct places with the correct amount and correct type of refrigerant oil.
Or you can simply throw on a compressor on (which includes the bearing) and shoot in a couple of cans of Freon like everyone wants to do. Might last the Summer if the compressor was really locked up.
gmcjimmy_94
Dec 30, 2010 12:37 AM
bcw757
Jul 3, 2006 08:44 PM
SniperX13
Jun 4, 2006 02:59 PM
NJEMT
Jun 1, 2006 01:40 AM
tammikm
Oct 28, 2005 12:15 AM
