a/c compressor noise problem
Old Sep 4, 2010 | 08:11 PM
jm01gt's Avatar
jm01gt is on a distinguished road
Default a/c compressor noise problem
hi. Have a 99 s10 blazer with the 4.3l. Original compressor went bad, so headed to the junkyard and found the same one out of a 97. The problem is that the compressor works fine but is making noise at the pulley. And the tensioner seems to be
moving more then before. I checked and the 97 calls for a 960k6 belt and my 99 has a 950 on it. Do i need to get the 960, and will that elimanate the pulley noise.
Thanks!
Old Sep 4, 2010 | 08:14 PM
Is the pulley on the replacement compressor larger than the original? If not, you should not need a longer belt.
Old Sep 5, 2010 | 02:54 PM
jm01gt's Avatar
Yes, the pulley is almost an inch bigger than the original. Instead of a 950k6, which advance auto calls for, there is a 955 on it. Plus,
when i turn the compressor off, the noise stops. Maybe the clutch
is starting to go?
Old Sep 5, 2010 | 03:03 PM
Definitely sounds like the clutch is going bad.
matthewq94
May 31, 2014 11:40 PM
NT_Hardcore
Oct 4, 2011 11:08 AM
Firebird14
Jul 29, 2011 10:36 AM
gmcjimmy_94
Dec 30, 2010 12:37 AM
