A/C Delete?
Old Jun 5, 2010 | 11:36 PM
ZigZaggle's Avatar
ZigZaggle is on a distinguished road
Default A/C Delete?
what do you guys say is it a good idea or no?
Old Jun 5, 2010 | 11:56 PM
84BlazerS10's Avatar
why would you want to delete you a/c? Maby I like the luxury part too much.
Old Jun 6, 2010 | 12:00 AM
ZigZaggle's Avatar
Because my A/C does not work and i wouldnt use it anyways A/C is not worth spending money on fixing to me. I'd rather put that money towards a bush guard or sumthing. so i wanna know if it would be hard to do.
Old Jun 6, 2010 | 03:41 AM
rriddle3's Avatar
It may not be a big factor in Canada, but down here it would absolutely kill the general resale value.
Old Jun 6, 2010 | 11:28 AM
ZigZaggle's Avatar
Lolz its not gunna be resold. It has 280,000 k's on it haha.
Old Jun 6, 2010 | 12:34 PM
Well I don't think it would be hard just time consuming and you would have a big hole in your dash if your talking about removing everything.
Old Jun 6, 2010 | 02:31 PM
ZigZaggle's Avatar
no just the compressor and what not
Old Jun 6, 2010 | 04:35 PM
I think all you would have to do would be recover the refrigerant *the Montreal protocol made it illegal to vent the refrigerant into the atmosphere so make sure you use a recovery machine to pull out the refrigerant* drain the oil and just pull out your compressor,evaporator, receiver/dryer etc.
Old Jun 6, 2010 | 04:46 PM
ZigZaggle's Avatar
Because i figure with that gone and then when i get my CAI it would make the engine bay look a lot cleaner.Plus delete something to be driven so a minimal performance upgrade along with weight loss.
Old Jun 26, 2010 | 02:20 PM
old skool luvr's Avatar
just grab the A/C bypass pulley from an earlier (1st gen) non-A/C truck, along with the serpentine belt, remove the compressor & lines, then install the bypass pulley & belt.
just be sure to keep track of those part #'s for the future when you need to replace them.
if you want, pm me, i've got those part #'s around here somewhere (brother's Summer Dime is non-A/C), and i can also send you the belt routing for the different set-up.
