a c problems
Old Jun 28, 2010 | 09:09 PM
neal's Avatar
neal is on a distinguished road
Default a c problems
2002 zr2 blazer a c compresor is not working right, checked pressure and it is 55/60. compresor kicks on and off wont stay on, even when i bypass the pressure switch, is there any way to check out the compresor to see if it is bad
Old Jun 28, 2010 | 09:10 PM
cbr995's Avatar
You might be low on freon.
Old Jun 28, 2010 | 09:15 PM
neal's Avatar
i checked the freon it was 55/60 that is were it is were it should be at 100+ temp.
Old Jun 28, 2010 | 09:18 PM
cbr995's Avatar
I believe the freon needs to be checked by a machine that pulls it all out, and weighs it.
Old Jun 28, 2010 | 09:34 PM
neal's Avatar
Default ac problem
i am not low on feon it has to be in the compresor or some thing else
Old Jun 28, 2010 | 10:38 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Sometimes the LP switch connector receptacles get loose on the connector. Get a dental pick and just tighten them up a little. Worked for me a a couple of other guys.
Old Jun 29, 2010 | 05:47 AM
If it runs for a short period then shuts down, even with the LP switch bypassed, then you may actually have a high pressure situation which could be from an over-charge or from a plugged orifice tube.
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
