CAI - Too much air flow
Old Apr 9, 2020 | 11:59 PM
Mark Couture's Avatar
Mark Couture is on a distinguished road
Exclamation CAI - Too much air flow
I've recently installed a CAI on my 2000 ZR2 with 130k along with a new MAS. Since then, I've notice some throttling issues. After running diagnostics, I learned that the was actually TO MUCH air coming in. Any feed back or tips would greatly be appreciated.
Old Apr 10, 2020 | 12:21 AM
93S10TahoeLT's Avatar
What kind of throttling issues have you experienced?
Old Apr 10, 2020 | 12:36 AM
There seems to be some "bogging" when getting on the throttle along with a loss of power. Also, I've developed a shifting problem that I suspect is connected. It almost feels like the trans is slipping. I get through 1 and 2 but will not go to three. When I manually put it into 3, there's no power. I've had it scanned with an OBD reader and I get:
CO265 - (ABS module is bad, and already knew it)
PO101 - This is the code for the MAS out of range
PO303 - Random misfire
PO404 - EGR valve issue
PO420 - O2 sensor - I've recently hollowed out the CAT
The MAS is brand new and the problem only developed after the CAT delete. I'm not sure which way to go at this point. New plugs and wires are on the way along with the ABS board, and I'm going to look at the EGR valve tomorrow.
Old Apr 10, 2020 | 02:00 AM
Okay, cool. Was going to say.. clean EGR!!!
And P0303 is cylinder #3 misfire. For me, it was as simple as a plug wire popped off. These are tough engines.
See how it feels after you clean that EGR...
Old Apr 10, 2020 | 03:29 AM
Absolutely! I'll keep this thread posted. I'm new to the forum and I'm liking what I'm seeing so far. I build custom driveline components for a living so I'm all about drivetrain, axles, and what not. My only concern that's really bugging me is the shifting issue. I'm hoping that it's just underpowered and not reaching the RPM needed to shift. In not, I'm building up the courage to rebuild my 4L60e myself. THAT'S GOING TO BE A TRIP!!!!
Old Apr 10, 2020 | 07:11 AM
Billy1820's Avatar
Good luck with repairs. What type of hot air induction did you install?
Old Apr 10, 2020 | 10:52 AM
What indication was there in your diagnostic data that you had too much airflow? I find that hard to believe, since the airflow is metered by the throttle plate, not the air filter. Unless you're actually forcing air into the intake at a rate that exceeds what the fuel system can keep up with, there's really no such thing as "too much air".
Old Apr 10, 2020 | 05:43 PM
Well, Po101 is code for MAS out of range according to research and in conjunction with running diagnostics at idle. I'd have to run it again but I believe it was 8-9 cfm when it should be 6? But I may me off? That was metered by the mass airflow sensor.
Old Apr 10, 2020 | 10:12 PM
AJBert's Avatar
Try putting the old MAF sensor back in. That just might solve your problems.
Old Apr 11, 2020 | 06:50 AM
+1
Give it a good clean with the MAF sensor cleaner.
