Cam Bearings
Old Sep 8, 2017 | 08:22 AM
jaymo1's Avatar
jaymo1 is on a distinguished road
Default Cam Bearings
I have a 1996 chevy blazer (s10) with the 4.3L and am having trouble finding the correct information on where to put the oil holes in the cam bearings in relation to the oil hole in the block.
I can someone please point me in the right direction on this?
Old Sep 8, 2017 | 04:30 PM
The exact specs need be found somewhere else. Maybe a forum member has been on this track before.
IMHO
In general all small block engines from GM are bored from the crankshaft mains into the cam bearings.
The cam bearing bore may even have an annular channel.
Normally there is only one feeder hole so the bearing should be aligned with this bore.
Hope this helps.
Old Sep 11, 2017 | 07:18 AM
jaymo1's Avatar
Thank you
Hanr3
Engine & Internal
Feb 28, 2007 02:25 AM
ivannj
Jan 16, 2007 03:49 PM
zashwood
Engine & Internal
Sep 8, 2006 01:30 AM
blazingsadle
Street N Strip
May 26, 2006 07:25 AM
Junkyard Dog
Engine & Internal
Feb 25, 2006 04:44 PM
