Poor performance/acceleration
Old Sep 10, 2017 | 01:25 PM
Nodacrux's Avatar
Nodacrux is on a distinguished road
Default Poor performance/acceleration
Hello. First post here. Looking for help/ideas for my 98 blazer.
Drove great until I started getting egr codes. Finally figured out the cat was plugged causing back pressure.
Drove fine for a month or so now it's acting similar. Finally gave me a code on the freeway for tps. Replaced. code gone drove a little better. Replaced fuel filter drove a little better for a day or two.
after this I decided to just drive it since if I drive like an old man it's ok and drives normal. Certain times from a stop it would shudder like it was about to die.
Finally 2 days ago I get a code for cyl 2 misfire. Just replaced plugs, 1 was arcing through porcelain, 2 was gapped wrong >.060, distributor cap was missing the rear screw and was crusty, rotor was crusty. So I changed all the plugs, wires, cap, and rotor. Gapped to .060 per the emission sticker. It does run quite a bit smoother. Still having an acceleration problem if I try too fast. Replaced the pcv valve 5 mins ago but the hose was old so it broke of course. Now I'm waiting to pick up some hose so I can finish that. The one I pulled did pass the rattle test and didn't look horrible. So I doubt that's gonna change anything.
off the line it will get up and go. If I slow to take a turn then try to get on it or speed up to pass someone is just kinda sits there for a few seconds and then slowly picks up speed and rpm. Now it will do this faster if I back off the gas a little. I'm kinda at a loss now. Anyone else come across this issue?
170,000 btw.
Old Sep 10, 2017 | 02:47 PM
Transman304's Avatar
Try cleaning the MAF sensor. It will give symptoms as you described.
Poor performance/acceleration-img_4072.jpg
Old Sep 10, 2017 | 02:49 PM
Nodacrux's Avatar
Thanks. Haven't cleaned it since I've owned the car. I'll pick up a can today.
Old Sep 11, 2017 | 12:38 PM
Nodacrux's Avatar
Update: installed new pcv valve and hose. Cleaned maf. Drove worse today. Had trouble doing speed limit on freeway (65) I have a sneaking suspicion that the catalytic converter is about to **** the bed again. I'll try a back pressure test again tomorrow when I get to work. Throttle to the floor on freeway hit 55 and losing speed. No codes.
BlackMatter
Feb 16, 2012 10:27 PM
raptorman
Sep 15, 2010 08:10 AM
99 Blazer 4 door
May 5, 2010 12:29 AM
Falconator
Aug 4, 2009 09:45 AM
posetha
Jan 5, 2009 08:41 AM
