Cant find Engine temp Sender 1 pin 1991 s10 blazer
Hello,
So my temp gauge is not working in my truck. So I found the sensor on the passenger side of the engine block and removed the connector. Its a single wire. I touched it to ground to test the gauge and the gauge is working. This tells me the sensor is bad. So I go to Advance auto parts to order a new one. They either cant order it or cant find one that has a single pin on it. All they can find is the double pin. I already replaced that one. It goes next to the thermostat housing. I called some other shops and they cant find a single pin sensor either. Does anyone know where I can buy one or have a part number that I can use to find the one I need??
I believe I have finally found the one I need. O'riellys has it I guess. Here it is for any future people who may have this problem. Autozone and advance auto parts cant even order this but O'riellys has it in stock.
MasterPro Ignition 2-8349 - Temperature Switch | O'Reilly Auto Parts
zakm0n
Jan 9, 2011 07:31 PM
PROJECT85K5
Dec 6, 2009 10:55 PM
Pee_Beds
Apr 22, 2009 09:12 AM
