Can't get oil filter off
Old Feb 18, 2015 | 09:12 AM
Cody Zakowski's Avatar
Cody Zakowski is on a distinguished road
Default Can't get oil filter off
Hi, I'm helping my buddy do a tune up on his 93 blazer 4x4. The problem I ran into is the oil filter that is located behind the driver's side headlight, I can not get it off for the life of me using the clamp. Just wondering if anyone knows if that screw/bolt above the filter is a Set screw of some sort that is keeping the filter in place because of the way it is hanging? Any help would help a ton. Thanks!
Old Feb 18, 2015 | 09:24 AM
The only thing that keeps the filter in place is the gasket tension from tightening down the filter initially. There are no set screws or other backup means of filter retention. If someone over tightened it the last time, it can be a real bear to get it back off. I have always had good luck with filter straps, but sometimes a screw driver through the side of the filter needs to be done as a last resort. Heck, there have been a few were I have had to tear the filter housing apart to get at the top plate to then use a punch & hammer into the holes in the top to get it to release...
Old Feb 18, 2015 | 09:29 AM
Thank you, I might have to try the screw driver or tear down the housing, This thing is stuck using the strap me and my buddy both tried with very little movement of the filter. The last time he had it done he took it to a shop, I was like did they torque this thing up in there or what lol. Thanks very much for the quick reply and suggestions, now I know what other options I got to get this dang thing off and a new one put on.
Old Feb 18, 2015 | 09:37 AM
BirchyBoy's Avatar
BirchyBoy is on a distinguished road
When you put the new one on, rub a little oil on the ring and it should help next time around.
Old Feb 18, 2015 | 06:39 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
And they only need to be hand tight and 1/2 more turn with a strap wrench when you put the new one on.
Old Feb 18, 2015 | 07:46 PM
rexazz2's Avatar
chances are the last one was put on dry
when you get the old one off make sure the gasket comes off with the old filter
as stated make sure to oil new filter gasket before installing
Old Feb 22, 2015 | 08:24 AM
TZFBird's Avatar
TZFBird is on a distinguished road
You can still over tighten a filter by hand. I have got them tight enough by hand to end up in this same issue.
I lube them as stated, install filter using two fingers(or until the gasket makes contact) and then give it a 1/2 turn. So far I have never had one leak and have always got them back off by hand.
Old Feb 22, 2015 | 01:46 PM
Gregg64's Avatar
Thats pretty much what i mean by hand tight. some guys can really gorilla things with one hand though. It doesnt take much to get these on with the proper amount of torque. You need to let the gasket do it's job. And yes, always lube the gasket. I even fill the filter with new oil before i install them.
Codeman
Dec 28, 2014 09:57 PM
cahlersmeyer
Nov 12, 2011 06:09 PM
mudcat
20
May 4, 2011 05:47 AM
88s10Blazer
Apr 19, 2010 06:27 PM
90K5Blazer
Oct 7, 2009 10:01 PM
