Cant move Air intake cover
Ok so trying to replace the camshaft sensor on the distributor, I have to remove the air intake on top of the engine block, I think its called the phyelm air intake or something, to actually get to the distributor. One problem- I just can't seem to get the thing to budge. I undid all the bolts, took off the sensor, and tried to release the seal by pulling a vacuum hose, and nothing has even affected it. It feel like its being held in place. Has anyone else had this issue or am I just missing something important? Can anyone help? I can try and provide pics but my camera doesn't like to work all that much. Thanks guys
this will cover more then you need but will show you how to take top end apart.
http://www.handymanliness.com/archiv..._99_Jimmy.html
hope that helps.
hope that helps.
Thanks! I was able to get it off the engine and take apart most the distributor. Now I have another question (sorry if these questions seem very obvious, I just learning how to do this): How do I get the distributor off? According to the chiltons manual I should just be able to loosen the clamp bolt and it comes right up but I have no idea how to loosen the bolt. I can't fit a wrench or a rachet in the small space so is there something I need to move? Something else I have to do before I can lift the distributor out? I will post pics as soon as possible.
Here are some pictures with what I am dealing with. Am I missing a step or do I need to move something? I have no idea what to do. Please help
Last edited by swartlkk; 11-06-2011 at 08:29 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Stuck In Muddy Mo
Nitrous, Super Chargers, & Turbos
01-27-2014 02:32 AM
ComputerNerdBD
Headers, Intake, & Exhaust
01-05-2012 04:53 PM
dimmuborgir6nik6
10-02-2008 06:51 AM
