Cap and Rotor replacement on 97 Blazer
Old Jun 15, 2015 | 07:13 PM
gidgigoo17's Avatar
gidgigoo17 is on a distinguished road
Default Cap and Rotor replacement on 97 Blazer
97 Blazer replaced cap and rotor with delco parts to try to cure a miss. Have found that the screws on rotor do not tighten completely. What do I do now?
Old Jun 16, 2015 | 08:33 AM
The new rotor should have come with new screws and thread locker already on them. If the screws are stripped, replace them. If the distributor is stripped, you can try to repair the existing threads, tap new threads, or replace the distributor. The rotor is keyed on the under side so it can only be installed one way.
Old Jun 16, 2015 | 08:46 AM
burned's Avatar
burned is on a distinguished road
Its common for the plastic distributor to crack around the screw holes.
If you need to replace it:
GM CHEVY V-6 VORTEC DISTRIBUTOR ALUMINUM BODY
Old Jun 22, 2015 | 09:43 AM
DesertStorm's Avatar
i would highly recommend the skip white distributor. no plastic parts on it.. everything is either steel (shaft) or aluminum (where the rotor and cap mount)
Old Jun 22, 2015 | 06:04 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
& half the cost to boot..............
er0ck273
Aug 24, 2015 12:22 PM
louie424
14
Nov 11, 2009 11:26 PM
dirtbagger
Feb 25, 2009 07:51 AM
blazinblack
Performance & Brainstorming
Jan 28, 2008 03:36 PM
kornphlake
Aug 11, 2006 05:55 AM
