Car shuts off while driving battery light comes on?
Old Apr 25, 2013 | 05:39 PM
amp042's Avatar
amp042 is on a distinguished road
Exclamation Car shuts off while driving battery light comes on?
This has happened twice now One the other day and today. I was driving getting of a ramp on I-19 when i come to a semi-full stop my car shuts off. My RPMs, Oil, Everyone drops to 0 and the battery light came one. Thank god it was a red light. I just turned the ignition switch again and it started off. Any suggestions why this is happening. 1995 Blazer LS 4x4.
On another note, i had a squeaky pulley so i sprayed some silicon lube spray to get rid of it. The squeak is gone, but now this. I don't know if its just the belt slipping from the pulleys or if my Alternator is going bad. Hopefully its nothing too serious.. Never did this before I used the spray.
Old Apr 25, 2013 | 07:57 PM
rexazz2's Avatar
I dont think it has anything to do with spraying the belt
Unfortunately unless it stays dead it wil be very tough to track down
Is the check engine light on when it is running?
If it is you need to read the codes and see what its saying
Old Apr 25, 2013 | 08:45 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
If it only happens after a long trip maybe the Torque converter clutch is sticking. Try shifting into neutral before you come to a stop and see if it still stalls.
Old Apr 25, 2013 | 08:51 PM
warthogdriver's Avatar
if this happened right after you sprayed the belt it may be the cause. have the bat and alternator tested as well. take the belt off and clean it up...maybe to slick now.
Old Apr 25, 2013 | 08:55 PM
rexazz2's Avatar
it starts up again , if the belt was slipping to the point the voltage was low and stall it should not start back up
Old Apr 26, 2013 | 01:33 AM
amp042's Avatar
So I've been looking online and what I've found is. It can either be my EGR. A faulty TCCS or a clogged up fuel filter. I also forgot to mention my PCV valve hose is busted. Could that be it?
Old Apr 26, 2013 | 07:39 AM
busted PCV hose will cause a large vacuum leak. It could casue issues.
Old Apr 26, 2013 | 09:58 AM
amp042's Avatar
Thing is I've been driving around with a busted hose for a while and never gave me any problems. Did it again this morning. Seems to be every time that I'm coming off the freeway, except this time it took a little for it to start. So, probably a faulty Torque converter clutch.
Old Apr 26, 2013 | 10:16 AM
Well, EGR can have the same effect too. But if its the TCC clutch stalling it then putting the truck in neutral will make it not stall, the TCC clutch acts just like a clutch on a stick shift. If its engaged when the car stops it stalls the engine just as if you stopped a stick shift without pushing the clutch pedal to disengage the clutch. If the EGR is sticking it will not matter what gear you are in as this is directly engine related. Both EGR and TCC are activated during high speed, low rpm travel like cruising down the interstate. If one fails to disengage when you come back to idle it could cause problems.
Old Apr 26, 2013 | 06:29 PM
amp042's Avatar
So it shuts off even in neutral. EGR then huh?
