carbeurated 4.3L in 1999 jimmy
Old Nov 30, 2010 | 01:44 PM
musicvalley's Avatar
musicvalley is on a distinguished road
Default carbeurated 4.3L in 1999 jimmy
hello ... I have a carbeurated 4.3L from a pre 1990 S10 ... I want to put a "true" HEI distributer on it and put it in my 1999 Jimmy 4X4 ... my question is will the transmission shift properly ? Should I leave the HEI dist that is currently on the donor engine (it has a 4-pin jack coming out of the base which I assume controls the advance and has the tachometer info) - is there a way to splice this into the current 1999 wiring harness so the trans "knows" when to shift ? can I go with a straight HEI w/ vacuum advance ? (thats what I prefer) - what do I have to do in order to make it so the computer controlled transmission shifts properly ? can it be done ?? thank you , marc
Old Nov 30, 2010 | 02:51 PM
Short answer - No. Slightly longer answer - not without a lot of work and/or a stand-alone controller for the 4L60E.
Also, there are a LOT of systems in the truck that communicate with the PCM so if you do away with the stock PCM, you will likely have many other things that won't work.
kamilkowalski
Apr 30, 2015 08:36 PM
Lord Letto
Oct 24, 2009 05:01 PM
nitromt
Jul 18, 2009 10:05 AM
496 BB
Jan 23, 2009 06:46 AM
jimmysjimmy
Dec 17, 2008 09:45 AM
