rough idle, fowl odor
Old Nov 27, 2010 | 08:34 PM
jrblazer2003's Avatar
jrblazer2003 is on a distinguished road
Default rough idle, fowl odor
My 2003 Blazer 4.3 6 cylinder is ruining bad, check engine lights on, checked to codes and it said random misfiring. Changed spark plugs wires, and still has rough idling. When I drive it shakes, and has a poping noise. Please if anyone can tell me what it sound like is wrong with it I would greatly appreciate it,,thanks.
Old Nov 27, 2010 | 08:47 PM
The foul odor could be a sign of a clogged catalytic converter. This can often be described as a rotten egg smell.
Old Nov 29, 2010 | 12:31 PM
Yes the odor does smell something like a rotten egg. How can I go by resolving this?
Old Nov 29, 2010 | 08:48 PM
If the catalytic converter is clogged, replacement is the resolution. You can confirm that it is the issue by disconnecting and removing one of the O2 sensors between the engine and the catalytic converter. There will be an exhaust leak which can be loud and it will set a code for the missing O2 sensor, but it should run and the alternative path for the exhaust to flow should restore power.
Old Nov 30, 2010 | 02:55 PM
Is this what's causing the random misfiring.
swartlkk
Jul 15, 2011 01:47 PM
chrisblaze
Jan 16, 2009 06:39 AM
mysssticghost
Dec 12, 2007 09:52 PM
sh1520
Aug 7, 2007 05:35 PM
hoffyinaz
Feb 1, 2007 06:23 AM
