Carbon Buildup on Intake
Old Oct 20, 2008 | 12:24 PM
chevygulr84's Avatar
chevygulr84 is an unknown quantity at this point
Default Carbon Buildup on Intake
Just found out yesterday while doing a routine check on fluids that I have carbon buildup on my intake manifold. Anybody have any suggestions as to why this may have happened and which cleaner is the best to use?
Old Oct 20, 2008 | 12:29 PM
WolfPack's Avatar
Default RE: Carbon Buildup on Intake
It just kinda happens with driving..
To clean it, use
annnd
Old Oct 20, 2008 | 12:33 PM
Make sure that what ever carbon cleaner you use, that it is sensor safe (ie no silicone).
Old Oct 20, 2008 | 12:35 PM
so is it dangerous to be driving the truck?
Old Oct 20, 2008 | 12:42 PM
If it is running properly, no.
Old Oct 20, 2008 | 04:05 PM
Hanr3's Avatar
When I replaced my intake manifold gasket I cleaned all the carbon out of my intake while I had it off. Amazing what a little elbow grease, solvent, and a metal tooth brush can do in an afternoon. There was a lot of carbon after 110,000 miles. Runs like a champ again.
Intake manifold gasket set is like $30. Well worth a half day or even a whole weekend of your time. You'd also be amazed at how much carbon builds up and where it builds up.
Old Oct 21, 2008 | 07:45 AM
Okay guys. Talked to my husband last night and we're gonna take it off and clean it this weekend. I've only owned this truck since last December, but am just now (at 177,XXX miles) starting to notice some issues.... leaking coolant, thermostat not working, hard shifting, etc.
Old Oct 23, 2008 | 02:56 PM
Hanr3's Avatar
More than likely the tranny issues are related to the engine issues. the puter monitors the engines perforamcne and adjusts he tranny performacne to maximize fuel emissions.
your non functioning coolant temp sensor could also lead to poor gas mileage.
Clean up the EGR while you ahve the intake off.
GMdesigner
Oct 29, 2013 03:23 PM
jacked85s10
Jun 22, 2011 05:50 PM
hjalbert3
Apr 7, 2010 03:36 PM
WolfPack
Nov 15, 2007 12:13 AM
hoovesofthunder
Headers, Intake, & Exhaust
Jan 29, 2005 10:23 AM
