cat, spark, vaccuum and more! HELP!
Old 10-14-2010, 01:49 PM
wilcleod's Avatar
wilcleod is on a distinguished road
Originally Posted by swartlkk
Your truck has 4 O2 sensors in total. Try removing the O2 sensor directly ahead of the cat and see if it runs better. It will be loud, but it is a diagnostic point. If that lets you get someplace to get things figured out further, so be it.
hey i really appreciate your kind words and help. after going through countless posts and hours of google. ill do what you say. I just hope it doesnt foul up the car worse than it is.
Old 10-14-2010, 02:03 PM
The two rear most O2 sensors (the ones closest to the cat fore & aft) are catalyst monitors only and do not have anything to do with the engine operation. Removing the pre-cat sensor will allow for more exhaust flow which should allow the engine to breath better than it is through a clogged cat.
Old 10-14-2010, 02:21 PM
wilcleod's Avatar
I know youre super busy but one fianl question...
Is there any diagrams or schematics where i can get detailed info on removing that sensor. Im not familliar with what tools will be needed or location of the sensor, will i need to jack the car up and so on. is this relativley easy to accomplish?
Old 10-14-2010, 02:27 PM
I believe it's a 22mm wrench that is required for the O2 sensor. As I have said and as the schematic below shows, it will be located on the exhaust pipe directly ahead of the cat. You want to remove the B1S2 sensor.
Old 10-14-2010, 03:07 PM
wilcleod's Avatar
ok ive pulled the o2 sensor from the exhaust manifold.. now do i leave it plugged into the computer module or leave it connected and tie strap the sensor to the frame work
Old 10-14-2010, 03:10 PM
wilcleod's Avatar
i mean do i leave it plugged in or take the whole sensor out and just leave the plug empty
Old 10-14-2010, 03:16 PM
Take the whole sensor out and leave the plug empty. This will set a B1S2 code or two, but it will keep the sensor from being messed up any more than it already may be. I would tape up the connector so it doesn't get too dirty and tuck it up safely so it doesn't get burnt on the exhaust.
If you plan on driving a long distance with it like this, you may want to fab up a little deflector to keep the exhaust from damaging anything on the transmission since the port points towards the trans.
mwbrown4
04-13-2014 02:39 PM
kxaz145
04-17-2011 12:56 PM
PaulO2288
Headers, Intake, & Exhaust
17
01-20-2010 01:39 PM
matclark
06-29-2008 11:29 AM
djbass_mekanik
04-22-2006 06:15 AM
Quick Reply: cat, spark, vaccuum and more! HELP!
