Catalytic Converter (Changing)
Hello car gurus! I need more advice here. Looking to sell my husband's mazda pick-up truck, and purchase a 97' Blazer with 130,XXX miles however the owner says it won't pass inspection - it has a bad Catalytic Converter. My question is, on average what's the difficulty and cost to change one out?
This truck is a STEAL for only $1500.00 and I'd hate to let it go.
Thanks all!
Thanks all!
well you can get them for around $200. for a shop to install just the catalytic converter would be probably $400 including parts. i've never replaced one on the blazer, just on my jetta vr6 and it was $1100.
It's not that bad and you can find them online for under $150.
Basically, it's just a few bolts. Spray with penetrating oil and remove them. If the bolts are just on a clamp, break them off for easier removal and replace the clamp with a new one. There are bolts to a mounting bracket as well as bolts to the pipes, but one you've got them all out it's pretty easy.
Note: this info is for a '93/'94; I really am not sure if the '97 is more or less complicated.
You can get a direct fit for under $200 (CLICK HERE for a search at summitracing.com - hopefully it works) and replace it in your driveway. You should be able to get a universal installed for much cheaper than that, but it would require some cutting and welding.
88s10Blazer
Sep 21, 2007 06:50 PM
sgtbrum
Dec 18, 2006 11:29 AM
