spring time tranny swap
Old Dec 22, 2008 | 11:33 AM
quik1964's Avatar
quik1964 is an unknown quantity at this point
Default spring time tranny swap
Ok guys this is the thorn in my side!
My WIFE'S 94 S15 Jimmy has no reverse in her auto tranny, I figure that i'll have to swap trannys come spring, cant even see her truck under all the snow, any little tech tips or tricks will make things easier when the time comes.
I do not have a garageto do this in nor do i have an engine lift to to the "big pull"
so it is a driveway repair
4.3 Vortec 4dr 4wd i believe it has the 4L60e tran
Thanx for whatever help you can give me
Wife happy.....Me happy
Old Dec 22, 2008 | 11:39 AM
Default RE: spring time tranny swap
You will have to make sure that you get a 93-94 4L60E to swap in as in 95 they changed to a PWM controller for the torque converter lockup.
Other than that, Take your time. The bell housing bolts can be fun. Just make sure that you have enough extensions to get from the those bolts to the back of the transmission. The upper ones can be accessed by dropping the back of the transmission down slightly, but be careful not to destroy the distributor.
Old Dec 22, 2008 | 11:44 AM
quik1964's Avatar
would a 91 tranny and transfer case be ok?
I got a working pair for 50 bucks
Old Dec 22, 2008 | 02:00 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
91 is 4L60, not 4L60e. It isn't a match to your truck. Neither would be a 92. Only 93-94 trannies are direct matches.
Old Dec 22, 2008 | 03:46 PM
Hanr3's Avatar
Tips [8D]
https://blazerforum.com/m_29933/tm.htm
Old Dec 23, 2008 | 11:19 PM
quik1964's Avatar
how do you tell the difference between the the 4L60 and the 4L60e?
And I was wrong on the year of my wifes truck hers is a 1993 Jimmy.
Old Dec 24, 2008 | 07:25 AM
She still has a 4L60E. 1993 is the year they switched from the 4L60 (aka 700R4) to the 4L60E. The 4L60 is hydraulically controlled and should have a TV cable; the 4L60E is electronically controlled and will not.
Old Dec 26, 2008 | 11:15 AM
Hanr3's Avatar
Look on the passengers side of hte tranny. Either there will be a wiring connection (4L60E) or a cable connection (700R4/4L60).
jatkins3983
Aug 13, 2015 11:57 AM
karmtec
Sep 2, 2011 06:06 PM
dandmprivate
May 9, 2010 05:48 PM
luckyferg1313
Lifting Tech
Apr 21, 2010 09:47 PM
Benedict1337
Apr 9, 2010 02:05 PM
