Changed Flywheel and Starter, Still grinding
Old Feb 4, 2014 | 09:15 PM
Jason10476's Avatar
Jason10476 is on a distinguished road
Default Changed Flywheel and Starter, Still grinding
So I changed the starter and flywheel in my 2000 blazer and it worked fine for about a week. Then this morning it starting to make the grinding noise again and now won't start. I don't know what else to do
Old Feb 4, 2014 | 10:01 PM
TZFBird's Avatar
TZFBird is on a distinguished road
I would start by checking the gap between the starter and flywheel when the bendix is energized. To do this you'll need to remove whatever covers are required to see the flywheel where the starter meets it. Then remove the positive cable from the starter but leave the solenoid wire connected. Have someone turn the key and engage the starter so it extends and meshes with the flywheel but does not turn the engine. You can then get a visual on how the starter and flywheel meet. I don't think that is your problem but it's a place to start. There shouldn't be an issue there but you never know. If there are shims between the block and starter, those should be removed. My first car had shims installed for some reason and it ate the teeth off the flexplate within a few months of owning it. I believe an engine stops in the same place every time which is why the teeth will wear off in only one spot.
Old Apr 6, 2015 | 08:12 PM
flashyB's Avatar
flashyB is on a distinguished road
i was having a similar problem in my 97 blazer, the outer bolt hole is cracked which seem to make the back end of the starter raise while i was tightening the bolt, which made the gear end of the starter lower away from the flywheel. i placed a nail between the starter and the block on the opposite side of the outer bolt from the flywheel, which is accessible through the wheel well and doesn't require you to remove the starter just loosen the bolts until you have enough room to fit the nail in place then tighten the bolts. for me doing this has stopped the grinding, although the bolt does come loose every now and then and needs to be tightened up. if anyone has questions feel free to email me at bgehringer2003@yahoo.com
Old Sep 26, 2021 | 05:28 PM
Skullkrusher's Avatar
Skullkrusher is on a distinguished road
Default Starer
i have the same issue on my99 chevy blazer
dumbfounded new flywheel and starter but keeps grinding.
Old Sep 26, 2021 | 05:42 PM
GeorgeLG's Avatar
You need to check the engagement pattern with some paint or a marker to see your depth engagement and the clearance to the teeth peaks. This will get you started:
George
Old Sep 27, 2021 | 05:18 PM
Zsadist0417's Avatar
Zsadist0417 is on a distinguished road
Okay. There's a couple things you can do, I'm currently dealing with a similar issue. Step one is to make sure the Flexplate (or flywheel) is on the correct way. I made the rookie mistake of putting mine on backwards the first time. The weight faces the motor. You could easily just remove the starter (after disconnecting the battery) without undoing the wires to it. Turn the crank a full 360 or until you see the weight.
Clearance is a big part of the starter and flexplate. To be honest with you, I've found that as long as it's the same flywheel and starter as factory, you shouldn't need one. Wouldn't hurt to try though.
A bent starter bolt, even a tad bit, can allow the starter to kick away from the flexplate and just grind. It's worth looking into.
Good luck to you
Old Sep 27, 2021 | 07:14 PM
So Jason started the thread in 2014,but skullbrought it back to life yesterday.
Hopefully Jason fixed the problem,but I will say that you message is still helpful to skull, so would be more for him lol... good 2 cents tho!
Old Sep 27, 2021 | 08:10 PM
GeorgeLG's Avatar
Zombie threads.
George
Old Sep 27, 2021 | 10:27 PM
Always there to haunt us!!
SorenG
Mar 22, 2021 08:31 PM
thomas80
Dec 6, 2013 08:59 PM
mouse23004
Apr 29, 2013 09:42 PM
BlazerBabe
Sep 10, 2012 11:51 AM
LoLoS10Blazer87
Jan 25, 2006 01:48 PM
