Check engine light
Old Jul 29, 2008 | 05:21 PM
ptg327's Avatar
ptg327 is an unknown quantity at this point
Default Check engine light
anybody know anything about a charcoal canister that deals with fumes from the gas tank and lines when the vehicle is not running
Old Jul 29, 2008 | 11:31 PM
WolfPack's Avatar
Default RE: Check engine light
called the evap canister. located drivers side, in the rear bumper end.
Old Jul 30, 2008 | 09:28 AM
blazinjeeps's Avatar
blazinjeeps is an unknown quantity at this point
If you are having a problem with it, replace the filter before you go and replace the whole thing. It could save you some $$
Old Jul 31, 2008 | 06:04 PM
ptg327's Avatar
it's back by the bumper? do you know hom much it is to replace the filter and if its easy.
Old Jul 31, 2008 | 06:05 PM
ptg327's Avatar
how do i replace it? where is it located? is it cheap and easy to fix. thanks
Old Aug 1, 2008 | 12:51 AM
WolfPack's Avatar
Give us some more info..why do you think it needs replacing? The problem with the Evap system is that it is very hard to trace the actual problem. What was the actual code number (P_ _ _ _) for your evap fault?
It is inside the bumper end cap, just to the left of the shackle and leaf spring. If you look under the truck back there, its the big black box with lines running to it. If you're dead set on replacement, the canister runs ~$100 online, parts stores will be a little more. Could also be a solonoid or valve, each running ~$30-50
Old Aug 2, 2008 | 12:04 PM
ptg327's Avatar
1992 S10 Blazer. CODE 45. O2 sensor indicates rich exhaust. which is true on start up. also check the evaporative charcoal canister and it's components for presence of fuel andchange O2 sensor. which i have done.
zombiewoof
Feb 1, 2009 12:06 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
