checkengine light?
Old Feb 17, 2010 | 08:22 PM
offroader1994's Avatar
offroader1994 is on a distinguished road
Question checkengine light?
on my way home today my light came on. took it to auto zone they pulled the code it said low running temperature and tem regulation. has anybody had this issue before? the other ? is how do i get the light to go off?
Old Feb 17, 2010 | 08:26 PM
A little more information is required... What was the specific code? What are you driving?
Old Feb 17, 2010 | 08:36 PM
it is an 01 4dr 4x4 auto. the handheld unit said low running temperature and or temp regulation. it did not show a number or anything.
Old Feb 17, 2010 | 08:58 PM
On a quick browse through the DTC listing for your year, I cannot locate a code that sounds like what you are describing. I know there is one, but I cannot justify searching for it when you can just get it with a scan tool and someone that actually knows how to use it.
Old Feb 18, 2010 | 06:51 AM
Can you tell me how to get the light to go off? I am going to change the thermostat tommorow evening and see if that is what the problem is. On the way home today i am going to stop be Advance auto and let them check the code and see if they get the same thing as auto zone did.
Old Feb 18, 2010 | 08:03 AM
If you correct the problem, the light should go away on its own. If you really want to reset it yourself, just disconnect the battery while you are working on the engine. Safe working practice is to do this anyway.
Old Feb 22, 2010 | 06:30 AM
Replaced the thermostat and the light wen off and has not come back on. thanks for the info swartlkk.
damageinc98
Jul 12, 2010 10:47 PM
dimmuborgir6nik6
Jan 23, 2008 07:52 PM
95_Blazer
Dec 6, 2007 09:44 AM
megtom2
Nov 24, 2007 10:36 AM
Deezy
Oct 25, 2007 08:58 PM
