cleaning pulleys
Old Apr 19, 2007 | 10:40 PM
gserve's Avatar
gserve is an unknown quantity at this point
Default cleaning pulleys
How do you clean the pulleys. I have replaced the serpentine belt and the noise stops for a few months than comes back only when its cold and then goes away. Now it is squeaking all the time. Please Help!! Thanks Any other suggestions?
Old Apr 19, 2007 | 10:51 PM
Default RE: cleaning pulleys
What kind of belt are you using? Have you inspected the pulleys to see if they need cleaning? I would think that a simple wire brush and just spinning the various pulleys (both grooved and smooth) would be sufficient enough cleaning. You may want to wipe them down later with a rag soaked in brake parts cleaner to remove any grease/oil/etc. Just make sure that everything is all dried off before putting on a new belt. I have had great luck with the Goodyear Gatorback belt on my Bravada. Over 2 years now and still looks like new with no squeaks.
01extreme
Engine & Internal
Feb 24, 2007 02:05 PM
blazingsadle
18
Jan 13, 2007 09:06 PM
ivannj
Jan 14, 2006 11:41 PM
V6 Vortec Jimmy
Engine & Internal
Mar 14, 2005 07:45 PM
timetoblaze
Engine & Internal
Feb 18, 2005 04:12 AM
