Clutch fan removal
On my 2000 blazer with the 4.3 V6, I need to remove the clutch fan assembly, but I can't figure out how. It says the large nut is threaded onto the water pump shaft, but I can't figure out how to stop the water pump from turning while I turn the large nut. I know the answer will be simple, but I am stumped.
There is a special tool for that but, I just used a ratchet tie down to keep it from slipping and a big wrench. It unscrews in normal ccw direction. I think I had to apply a little heat to loosen the grip. Pic is not very good but it will get the point across.
Don
Don
Don
Don
cheesequaker
Apr 25, 2012 01:44 PM
MintyMadness
Jul 13, 2011 12:37 AM
