Code Guys please help
Just had the 1995 Chevrolet Blazer put on a computer at a local shop because it is missing and stumbly. I put on new plugs, wires, distributor cap and rotor. It sill misses like crazy and dies.
It threw one code. P1406
RE: Code Guys please help
It's the EGR, probably has some carbon build up in it. I would take it off and clean it out. Use the search to find a how to on how to remove and clean it.
How to you get to the EGR? I could get the bottom right bolt out ( fell down in the engine I will deal with that lol ) but I cant get to the left bolt at all. I tried a socket and ratchet and even a wrench but cant get to it.
I found alot of posts on how to clean it but none on how to get that dang bolt out
I dont have your version of the blazer but whats blocking it? try removing the belt the tensioner may be in the way
yeah the belt, tensioner, and ac are in the way. Its 40 degrees and dark so it will have to wait for tomorrow. I have to pick up an egr gasket anyway.
I had to get at mine with a swiveling extension, but when you get the gasket grab the one with the screen in it to help prevent this problem from happening down the road. Let us know how everything goes. Goodluck.
yeah I have read about that gasket, does autozone have them?
yea they do its Tomco / Klean Screen EGR Gasket Kit
http://www.autozone.com/R,108452/veh...ductDetail.htm
Hey thanks, I will pick it up tomorrow
Please do not double post your problems. I have removed the references to this code from your previous thread. You, as the author have the right to take a thread in whatever direction you please, but do not ask the same question in multiple locations.
eddy78741
09-19-2013 03:14 AM
buck8907
09-17-2009 06:15 PM
98blazr
44
08-21-2009 01:17 AM
