cold starting issue
Old Jan 8, 2009 | 10:42 AM
boater00's Avatar
boater00 is an unknown quantity at this point
Default cold starting issue
Hello my 2000 Blazer wont start when cold. We did all the reg tune up stuff plugs,cap,wires. It starts great if I leave inside heated garage. We checked fuel pressure readings when it was warmish held around 60psi all night. We checked the pressure this morning
-10c outside it is also was at 60psi when key is in on position but falls of to 45psi when you startcranking motor over. It did start after a few tryspressure ran at 55psi when running. We are thinking of replacing fuel pump should cranking pressure be greater then 45 psi when engine is cranking over?
Thanks Jamie
Old Jan 8, 2009 | 11:27 AM
rriddle3's Avatar
Default RE: cold starting issue
Read this post and get back with any questions you may have.
Old Jan 8, 2009 | 12:43 PM
boater00's Avatar
I read all that. Im still wondering what the presure would read during cranking-45psi seems low? I didnt really see that in the other thread Thanks Jamie
Old Jan 8, 2009 | 12:53 PM
Second sentence from the link above... The pressure should never drop below 55psi per the book.
Old Jan 8, 2009 | 12:55 PM
rriddle3's Avatar
Unfortunately, the internet filters here at work don't let me view the diagnostic charts in the post, so I am unable to answer your question right now.
Old Jan 8, 2009 | 01:07 PM
boater00's Avatar
Hey Kyle Thanks I didnt see that. Im thinking we will replace the fuel pump its the original. Jamie
stevenhousden
Jul 6, 2014 05:56 PM
dougg01
Jan 5, 2010 03:47 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
Smoked
60
Nov 24, 2008 07:48 AM
as2higpark
Oct 18, 2007 12:18 PM
