Considering selling the Wagoneer and stuffing 454 in Blazer..
Old Apr 22, 2013 | 04:54 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Dome pistons will give you a much higher compression ratio than 9.5-1.Probaly like 11-1 which you wont be able to run on pump gas.Stick with flat tops with either 2-4 valve reliefs.Also what kind of rearend are you ging to run open carrier r posi?I`d go with 4.10 gear ratio
Old Apr 22, 2013 | 06:55 PM
Revelc's Avatar
Revelc is on a distinguished road
The ratios I have at the moment are 3.35 with 31" mud terrains
I will sell them and the axles so I can slap some different axles off of a 3/4 ton Chevy or a Blazer driveline.
Then I will get new 33 or 35" MT's
My current set up is spring under front. With a shackle flip and spring over my 4" lift will become probable around 10" depending on axle tube size. I want a street able off road/tow rig. The BBC engines are supposed to be torque monsters so it cant be too hard... right?
Old Apr 22, 2013 | 09:02 PM
I have more experience building torque masters out sbc but yes the big block can be built to suit your needs.Are you going to have any machine work done on the heads like porting and polishing millings and 3 angle valve job?
Old Apr 23, 2013 | 07:50 AM
As for tires I would stick with 31`s
Old Apr 23, 2013 | 08:00 AM
Revelc's Avatar
I am open to aluminum heads if shaving heads is required I wouldn't mind forking out some $$ for a compression bump that's safe.
Old Apr 24, 2013 | 09:04 AM
You can have safely .0025 milled off the heads no problem.I would also go with the rpm airgap performer intake also.Also on your engine build get it balanced and blue printed also.Yeah it cost extra buts its worth it.
Old Apr 25, 2013 | 09:29 AM
Revelc's Avatar
I'll be doing it right. Definitely balancing it. The engine will be supercharged later on with a few pounds so I want it to be right.
Old Apr 25, 2013 | 04:42 PM
Seems like you have a nice dream in the works.If your going with super charger ditch the stock rods and go with either H or I beam type.Also you are going to forged crank and pistons.Are yu building this engine or having someone build it for you?
Old Nov 20, 2018 | 05:14 AM
rriddle3's Avatar
*5 year old thread is now closed*
okiehuntr
Mar 25, 2018 08:05 AM
Blazerum
Feb 3, 2017 11:54 AM
Stettenbenz07
Performance & Brainstorming
Oct 10, 2015 08:47 AM
JTWard
Sep 20, 2015 09:10 PM
