coolant disappearing?
Old Oct 17, 2010 | 11:08 PM
kvesi122's Avatar
kvesi122 is on a distinguished road
Default coolant disappearing?
I noticed a tiny dribble of coolant coming from where my lower intake gasket would be but it's not steady by any means. I've lost maybe 1/4 of the coolant in my overflow over the past 3 months. Should I replace my gasket? I used un mixed coolant and may have used too much water when I swapped my radiator in may garage back in July. Any info would be greatly appreciated. The temp is fun and I haven't noticed any problems. The oil is still brown
Old Oct 18, 2010 | 01:12 AM
Bob'sblazer's Avatar
Bob'sblazer is on a distinguished road
I would asap... Leaks like that can signal you to a much worse blow out, or it will start feeding into the oil. Its worth it and in the long run you will have a better running engine.
Old Oct 18, 2010 | 10:36 AM
kvesi122's Avatar
You think it will be okay until Saturday? Just short 2 mile trips to and from work.
Old Oct 18, 2010 | 11:04 PM
should, but monitor the oil and coolant levels/condition try to keep off WOT if you can. small dribbles are bad,but can get bad fast
swells87
Jul 22, 2013 12:11 PM
Eric S
30
Jan 6, 2013 02:28 PM
phar54
Jan 13, 2012 07:56 PM
Octane92
Sep 9, 2010 11:31 PM
00blue4.3
Mar 3, 2010 10:04 AM
