Coolant leaking on the drivers side
Old Dec 6, 2013 | 05:58 PM
janddcunningham's Avatar
janddcunningham is on a distinguished road
Question Coolant leaking on the drivers side
Hey Gang,
I have a 1997 blazer 4x4
It is leaking coolant on the drivers side and seems to be very low as you follow the radiator down I can see a wet spot under the fitting of he radiator. everything else is dry. the radiator is dry no sign of leak above until you look way down to that last bit of it under that fitting.
Radiator replace in 2008 135,000 miles
Oil cooler lines replace in 2011
Water pump replaced in 2011
lower manifold gaskets replaced in 2011
blazer now has 175,000 miles on it
Also I was wondering if putting in some bars leak if that would work as a quick cheap fix and if so what could it do to other parts of the system I do not want to cost myself more money in the long run doing a quick fix you know??? have any of you used it and what is your experience with it?
my reservoir bottle is still at the same spot it was last time I check it at oil change 4 weeks ago
Thank you in advance to anyone who responds
Old Dec 6, 2013 | 06:10 PM
newguy's Avatar
bars leak will plug up your heater core unless you do exactly as the directions say. DRAIN ALL the anti freeze out, fill with water and bars stop leak, run as described. DRAIN ALL of that out and refill with anti freeze. A lot of work for a rad thats not that expensive
upmaine
Jul 9, 2012 12:31 PM
Wexinlo
Apr 6, 2011 11:35 PM
bertrenolds
Mar 27, 2011 11:04 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
fruccoman
Feb 15, 2006 07:08 PM
