coolant problem?
#21
I fluahed one hose when I flushed the core, but couldn't get the other off. I really hope its as simple as a pluggef up hose, cause I don't want to have to remove the whole dash. Thanks a lot for your help! People here are great!
#23
I could do that. I'm going to check the hose then flush the whole cooling system. If it doesn't work I'll bear through the cold till summer when I'm out of high-school and have more time between work to fix it.
#24
if you were able to flush the core and have no issues flushing it, it is most likely a hose. have you ever put bars stop leak in? i had used it once and had a hose plug up on me...i used it to limp till i could get the lower intake gasket fixed. worse case (hopefully) you need a new hose.
good luck
good luck
#25
No, I have never used it. The previous owner may have used it though. I haven't done a flush since i got it. The previous owner let the truck sit for a few years.He said he only drove it every once in a while. So that probably caused most of my problems with the blazer. If a hose to the heater core is plugged could that cause any engine problems that could be major? If not then I will just wait till I have more time to fix it.I have an hour of free time today and tomorrow between work, so anything that will take longer than that can't be done until friday or early saturday.
#26
Guys I'm confused here. I fluahed the heater core again, and both of its hoses this time. When I first warmed up the blazer the heat was warmer than it was but still cold, then it got cild again. I felt the hoses and the hose on the passenger side is hot, the other is cold. Even after just flushing the core and having nothing but clear water come out.
