CPI gone bad?
Old Jul 23, 2009 | 09:25 PM
00bluegtp's Avatar
00bluegtp is on a distinguished road
Default CPI gone bad?
have been trying to diag. this idle problem i have been having for a while now. I will first start off with what i have done. 1. I have replaced the fuel pressure regulator as i found that the passenger side of the lower intake was washed out, but did not fix the idle issue. 2. Cleaned and installed screened gasket on egr valve, still same issue. 3. Replaced fue pump and filter, still no fix. 4. Replaced distributor cap and rotor, still same ruff idle. Ohh and the plugs and wires are new within the past couple of weeks. So I was out driving the truck around and then took it home for it to cool off so i could pull the plugs and inspect them. I pulled the pugs and found that everyone of them was wet and smelled somwhat like fuel. I cleaned them off and reinstalled them and it ran well for about 30 seconds and them it started running rough again. It only runs rough at idle but the problem i am having is I have no black smoke or any smell of fuel for that matter. Do you guys just think my injector is leaking? What else could it be? I have checked the spark with one of those testers and it seems good, very bright. I ordered a new cpi and supply and return lines do you guys think that will repair it? The truck still has tons of power while accelerating.
Old Jul 23, 2009 | 09:29 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
You should still put new Ac plugs in her after you replace the spider, make sure you clean the EGR port when you have it apart.
Old Jul 24, 2009 | 12:18 AM
00bluegtp's Avatar
will do, I alreadt have the delco plugs ready to go into t soon as i complete the spider replacment.
prbjeepin
Apr 8, 2013 10:14 PM
nitmoves1962
Oct 5, 2009 05:36 PM
muskyman7272
Apr 30, 2008 03:42 PM
XRayTech
Sep 12, 2007 01:32 PM
hstt
May 21, 2007 07:39 PM
