cpi to tbi
Old Sep 28, 2007 | 03:13 PM
Default RE: cpi to tbi
Yes, to your '95 motor, they should be the same. Please put your vehicle information in your signature and attach it to your posts so questions can get answered more clearly.
Old Sep 29, 2007 | 08:56 PM
SirLDragon's Avatar
SirLDragon is an unknown quantity at this point
ORIGINAL: Hanr3
That answer depends on the year of the truck, not the CPI/TBI/fuel injection system.
In '95 GM changed the angle between the heads and intake manifold. Intakesprior to '95 can be swapped on engines prior to '95. Intakes after '95 can be swapped on engines after '95. You cannot swap intakes prior to '95 on engines after '95 and vice versa. That is hte simplified version.
Ok, that's completely off from what I've been told prior to this. And kind of confusing since the CPI ("W" code Vortec) intake is the same from '92 to '95. Or is there a difference to the inside of the lower plenum where the bolts are?
Old Sep 30, 2007 | 12:08 AM
Hanr3's Avatar
This may help.
http://www.babcox.com/editorial/ar/ar40047.htm
'95 is a confusing year. GM made changes over the life of the engine, however '95 is the most confusing.
deathman
Aug 14, 2011 11:25 PM
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
andrewhartley55
13
Nov 30, 2009 12:54 PM
chrisw1022
Nov 17, 2009 09:34 PM
dbleon
Jan 25, 2008 06:54 AM
