Crank but no start
Old Aug 16, 2018 | 01:20 PM
Trey Vander Laan's Avatar
Trey Vander Laan is on a distinguished road
Default Crank but no start
I need some help guys! I have a 1998 Blazer and it cranks but no start. Here is the catcher, when you take jumper cables to it and hook it to the battery and hook them up to another car and wait a second it starts up. I’ve had the alternator tested and it was fine. It also has a newer battery. I’ve also replaced the fuel filter.
Old Aug 21, 2018 | 12:40 AM
Have you separately charged the battery to make sure it is fully charged? Perhaps have you swapped the batteries?
Old Aug 21, 2018 | 05:26 PM
arick793's Avatar
arick793 is on a distinguished road
Well when you're cranking to start, you have 12 volts or less. When you crank while hooked to another running vehicle, you have close to 14 volts available. MAYBE if you have a failing fuel pump, the extra voltage is enough to give it the extra couple of psi fuel pressure needed to start? Will your truck start with quick start sprayed in the throttle body? Are you able to test your fuel pressure? Maybe turn the ignition on and off a couple of times, letting the fuel pump prime a few times to build up pressure, and then see if it will start on its own. Good luck!
Old Feb 14, 2019 | 06:03 PM
hdwingding's Avatar
hdwingding is on a distinguished road
hello. 1998. with 90k on engine and parts. cranks over great but wont start. sometimes with pedal floored it will "Huff a bit". i can smell gas.
Old Feb 15, 2019 | 05:17 PM
hdwingding's Avatar
now today it started after being in warm 60F garage.
Old Feb 15, 2019 | 08:21 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
you might want to start your own thread if you continue to have problems... I’d say maybe a frozen fuel line if it started when warmed up. Not a lot of details given to help troubleshoot.
Prolsc
Sep 6, 2019 04:52 PM
spiderx
Nov 23, 2012 12:03 PM
reidzap
Jan 30, 2011 08:11 PM
TheJuicer
Nov 15, 2010 10:29 AM
00blazerLS
17
Jul 6, 2008 07:44 PM
