Crank runs for 25-30 seconds then dies
Old Mar 17, 2025 | 08:52 PM
Morgan307's Avatar
Morgan307 is on a distinguished road
Default Crank runs for 25-30 seconds then dies
Hey guys needing some advice I’m working on 1989 Chevy s10 blazer 4.3L 4x4. I lost reverse so it sat for a couple years then I got back to it so I pulled out the 700r4 and rebuilt it in my kitchen… wife loves me… figured since I had t-case out take a look in side chain was sloppy so minimal rebuild kit.. slapped it back together. Dropped the gas tank good and clean replaced the in-line filter. New battery plugs wires cap rotor. …. Hit the key crank crank crank sputter checked vacuum lines … old cracked time for new new ones and t and the t valve crank crank crank same results so tbi off and deep cleaning new Iac valve new map and the module under the cap … oops accidentally left the vacuum line off the map sensor and it fired right up … ran for bout 20-30 seconds then it like key off I can see fuel pulsating and I have fire but it won’t start with map vac hooked up … I have searched and talked to other mechanics and can’t seem to figure it out … any and all advise tips tricks help
Old Mar 21, 2025 | 10:27 AM
GeorgeLG's Avatar
So when you crank but no start you have 1" of strong blue spark with a consistent cadence at the plugs but poor fuel pressure? What is the fuel pressure doing?
George
Old Mar 24, 2025 | 07:11 PM
Morgan307's Avatar
Yes I have spark and I don’t know psi on the line but I can see the fuel pulsation on the tbi
Old Apr 6, 2025 | 03:57 PM
daveca's Avatar
"I lost reverse so it sat for a couple years then I got back to it so I pulled out the 700r4 and rebuilt it in my kitchen… wife loves me…"
Our Hero!!!!
When youve changed all the mechanical parts and it still dont run, suspect ignition. What George said, blue- white spark is a MUST.
I had to put a bypass relay from ignition power to distributor due to bad wiring conections starving the ignition for power on my 1995.. Very important to put at least a DC voltmeter on the power at the distributor and timing light on the plug wires, an automotive oscilliscope is better but few have them.
varnerventures
31
Mar 23, 2019 09:47 AM
Klturi421
May 10, 2013 02:10 PM
thewickedk5
Engine & Internal
Oct 29, 2011 08:16 PM
TheJuicer
Nov 15, 2010 10:29 AM
88s10Blazer
Nov 6, 2006 03:32 PM
