Cranking but no start
Old Feb 2, 2016 | 01:52 PM
pitmama74's Avatar
pitmama74 is on a distinguished road
Default Cranking but no start
I have a 03 blazer with 4.3 vortec. Truck has been starting with no problems new battery and alter. But it has been getting terrible mpg and hesitation when rpm hits 2 to 2.5 kinda like a dead spot if it were carburetor. Took to corner on sun was fine. Monday morning just cranks and cranks with no start not even with starting fluid which caused a "poof " maf is clean. Fuel pump can be heard turning on and off. Fuel pressure a Schrader good, fuses good. I have been looking at other posts and my head is spinning. I do not have the money to replace a million things my husband recovering from back surgery and this is my only transportation. Can anyone please help ?? Fuel pump, and fuel filter was both replaced on the summer, along with wires, plugs, cap & button. And has had a large evap code leak which haven't been able to get checked out due to financial situation
Old Feb 2, 2016 | 08:26 PM
Has the check engine light been on recently while driving? If it doesn't start by adding fuel, the problem could be lack of spark? Have you checked if it has spark? (in the future, don't use starting fluid, way too dangerous).
Old Feb 2, 2016 | 09:18 PM
pitmama74's Avatar
Service engine light was on due to large evap leak which was never checked out but has been on since spring. This is 1st time it's never not started. Was getting horrible mpg and a lil hesitation here aND there. Don't know where to start can't afford to replace all the sensors. As soon as rain let's up my husband is going to check the spark. I'll update when I have an answer on that.
Old Feb 3, 2016 | 03:06 PM
We can help you diagnose the problem so you don't end up buying stuff that is not necessary. It will require some testing on your part, but we will guide you.
Have you had the codes retrieved since the current problem showed up? If not, we will need to know what codes are in memory, and the order that they are retrieved. If you haven't had the EVAP problem diagnosed and repaired, that code will still be in memory. We need to know if there are any additional codes in memory, and if so, which codes are they.
Old Feb 3, 2016 | 05:04 PM
pitmama74's Avatar
Update : followed the advise from you on a dif thread, with checking distributor cap no spark off maybe 2 or 3 and some corrosion. Replaced cap and button and it started. This will be getting done again soon as short on money and got cheap ****. So AC Delco will be getting put in. As for the EVAP code it's cleared out but I think it was P0455 and it's not the gas cap.
Old Feb 3, 2016 | 06:35 PM
Glad you got her going! Thanks for posting back.
ssulb
Nov 20, 2015 03:58 PM
wvboy18
Aug 29, 2012 09:38 AM
Freise
Mar 16, 2012 11:27 PM
trishharris
Aug 4, 2010 10:38 AM
