Crate motor help
Old Jun 15, 2015 | 10:46 AM
USMarine1108's Avatar
USMarine1108 is on a distinguished road
Default Crate motor help
My 96 S-10 Blazer, 4 dr 4wd 4.3V needs a new motor. I'd rather do a crate motor vs a junkyard motor. Rebuilt would be fine too.
So... Where do I find one? I'd like a long block and just be done with it. How do I decode the VIN to make sure I get the correct motor for plug and play?
I know 96 was a weird year with some 95 parts on it, I don't have OBDII I have the old version.
Old Jun 15, 2015 | 05:07 PM
AJBert's Avatar
Check out Jasper for a rebuilt engine. Quite a few folks have used them and I don't recall any problems. As for a crate, GM Performance.
You'll find Jasper a bit cheaper.
Old Jun 15, 2015 | 08:50 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
What he said....... one or the other......save yourself some headaches
Old Jun 15, 2015 | 09:41 PM
1995 was the hodge podge year using OBDI and OBD1.5 with 2 different ignition systems and 2 different computer controls. 1996 & 1997 were nearly identical to each other. Both of them were VIN "W" and both had OBDII engine controls.
Old Jun 16, 2015 | 09:39 AM
Thanks for the input guys. Jasper wants $1991 plus a $420 core charge. Seems high to me. Thoughts on that price?
Old Jun 16, 2015 | 09:42 AM
My VIN says 96 but I have the OBD 1.5. Also the radiator for a 96 didn't fit but a 95 radiator matched the factory one I pulled out.
Mine is a W code.
Old Jun 16, 2015 | 04:33 PM
1996 was required to have OBDII. 1995 was not, and could have OBD1.5
What is the 10th character of the VIN?
Is your alternator mounted on the driver side,
or the passenger side, of the engine?
Old Jun 16, 2015 | 06:15 PM
altoncustomtech's Avatar
Do more searching around the Internet. I was able to locate a Marshall reman engine for my '01 Jimmy for a little over $1400 on sale at one particular vendor.
I'm not going to guarantee that you can find one as cheap but cheaper than the Jasper price should be doable. For what it's worth that is the same price they gave me when I was searching for an engine.
Old Jun 16, 2015 | 08:50 PM
T
Top of the passenger side.
Old Jun 17, 2015 | 12:18 AM
07nhbpsi's Avatar
I unfortunately have a Marshall reman..........thankfully I didn't purchase it originally, I would never buy one of their motors after learning firsthand of the shortcut they took on my motor...........long story short, I had to remove the heads (stuck exhaust valve) turns out they like to use 'brass' valve guides..........well , let's just say they are ok for a short time but not long.......$300 later I got my heads back from the machine shop !! I can rest assured now that they are 'right' needless to say , I learned a very important lesson............ I suggest anyone to search for Marshall complaints..... Be prepared for lots of reading, turns out they also reman engines under other names, one thing seems to be for sure........lots of complaints........
