CV Joints Lost Grease
Old Oct 3, 2008 | 05:44 AM
wienerdog's Avatar
wienerdog is an unknown quantity at this point
Default CV Joints Lost Grease
The inner CV joints on my 99 Jimmy have lost their grease. Is there any way to pump gease back in without disassemply?
Thanks
Old Oct 3, 2008 | 06:39 AM
Default RE: CV Joints Lost Grease
Only if you want it to come right back out.
If the grease is leaking from the CV joint, then the boot has been damaged and needs to be replaced. I would not recommend you go with one of the time saver split boots as they are known to fail quickly. So you can either replace the boot on the axle shaft, or replace the axle shaft. Replacing the axle shaft itself is less time consuming, but more costly. Either way, the axle shaft must be removed from the truck. Properly replacing the boot itself requires a special tool to crimp on the clamps on either end of the boot.
TimoBlazer
Headers, Intake, & Exhaust
Dec 21, 2008 11:17 AM
Mickeymouse
Jun 22, 2008 03:05 PM
flyinbrad
Dec 4, 2007 02:51 PM
sasquatchfound
Detailing
Jul 5, 2007 12:36 PM
yzf125
Mar 13, 2006 12:53 PM
