Cylinder #2 misfire comes and goes
Old Sep 24, 2009 | 12:56 AM
bigrig1186's Avatar
bigrig1186 is on a distinguished road
Cool Cylinder #2 misfire comes and goes
i got a 2001 blazer 4.3l 4x4 with a cylinder 2 misfire that comes and goes every couple days sometimes you can feel the miss others you can't. i've replaced all common parts, plugs wires dist. rotor, also did compression on all cylinders all was fine. Replaced the fuel pump last week because the dealer dropped the tank for a sensor and broke the supply line fitting but god forbid i told them that because they can't do any wrong so i did it myself with no problem. Did the A.I.R. pump yesterday because there was a code for that also but the miss has been happening for about 1 month now im kinda stumped my only guess now is that its an injector? it is hard to start, if i push on the pedal when starting it doesn't make a difference, i was thinking maybe an injector seeping but nothing.
Old Sep 24, 2009 | 02:53 PM
rafa.jrbarajas's Avatar
rafa.jrbarajas is on a distinguished road
try checking the ignition coils and also look for a vacuum leak and also it could be a faulty injector
Old Sep 25, 2009 | 12:08 PM
bigrig1186's Avatar
i was looking around in the engine today just curious took off the intake and opened the throttle body and it was wet so now im thinking could it be the fuel pressure regulator? i know there have been some problems on these engines with the fuel issues under the intake so any1 have a similar find or problem?
Old Sep 25, 2009 | 05:13 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
with the plenum off turn the key to the "on" position..this will activate the fuel pump and send gas to the injector unit..see where the leak is..
Old Sep 25, 2009 | 11:52 PM
bigrig1186's Avatar
thankyou for the tip
Old Sep 26, 2009 | 11:12 PM
bigrig1186's Avatar
i replaced the FPR today the check engine light went away and it runs smooth now the only other question i have is my RPM's are at 550 is that correct?
Old Sep 26, 2009 | 11:14 PM
okvortec's Avatar
your idle will vary based on conditions such as weather, engine temp, etc. 550 is fine
Old Sep 27, 2009 | 10:56 PM
bigrig1186's Avatar
kewl then everything is fine for now hopefully for a long time thankyou
Skitzoape
Jul 3, 2012 05:46 PM
MissTina0301
Dec 18, 2010 03:17 PM
mbar
Nov 10, 2010 02:39 PM
Seabbatical
Jul 11, 2009 02:30 AM
blaze1925
Sep 20, 2005 11:54 PM
