Degreaser recommendation
Old Jul 26, 2011 | 02:11 PM
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
Default Degreaser recommendation
Hey everyone. Could I get a recommendation for a safe degreaser for removing oil from the undercarriage of the truck? I have an oil pan gasket leak that is covering the oil pan and transmission pan and gear oil on the front differential that I am trying to find the leak. There is more oil along the centerline of the vehicle on the crossmembers. I also have old oil from the rear axle (pinion seal, was replaced, I suspect it is seeping again) around the front of the differential (I don't know if it is gear oil or motor oil). Is there a degreaser that is safe for rubber parts that will do a good job? I could find several of them at Walmart, but I am concerned about accidentally hitting the rubber parts and gaskets.
Old Jul 26, 2011 | 04:15 PM
TripleBlackBlazer's Avatar
Simple Green. Follow the directions to dilute it. Spray it on liberally. Hose it off with a moderate stream of water.
Works great on engine bays and I just read a review from a grease monkey on a dragster pit crew that uses it to clean grease off his tools and parts.
Old Jul 26, 2011 | 11:06 PM
AJBert's Avatar
X2 on the Simple Green.
There are other degreasers that may do a better job but may not be as enviromentally safe or as safe to other materials. I've even used it to degrease my hands after finishing a job.
Old Jul 26, 2011 | 11:39 PM
xgiovannix12's Avatar
nice imma go buy me some so i can clean my Engine =)
Old Jul 27, 2011 | 06:59 AM
coolasice's Avatar
coolasice will become famous soon enough
i used gunk engine degreaser on mine, works great but engine has to be cold when applying....kinda flammable... i could use a couple more cans tho
Old Jul 27, 2011 | 10:23 AM
9Blazer6's Avatar
9Blazer6 is on a distinguished road
Purple Power, Bleach white, Simple Green, Engine degreaser in the white can with orange cap (cant remember the name) If you have a local detail shop near by stop and see them. I used to work for Detail King if anybodies familiar and they have some really great products. Specially tire shine =)
Old Jul 28, 2011 | 05:19 AM
coolasice's Avatar
That's the "GUNK" Brand engine degreaser, same as I used, i'm gonna try their foaming one next time...
Old Jul 28, 2011 | 06:43 AM
marksoftball's Avatar
marksoftball is an unknown quantity at this point
SUPER CLEAN. Its in a purple jug. Wear Gloves/goggles. Probably not friendly to the environment but its the best stuff I have ever used
Cuts through old grease and oil like warm butter. Highly recommend.
Mark
masrace
Headers, Intake, & Exhaust
Jun 29, 2010 12:40 PM
Spectreblazer
Feb 19, 2010 01:14 PM
mattd
Tires and Wheels
14
Jul 20, 2009 09:05 AM
marnepup
Apr 15, 2008 10:53 AM
ReB
Dec 13, 2006 03:24 AM
