desperate help
desperate help
hey ive finally decided to conver to manual. unfortunalty i cannot find a donor truck so my only option is to buy the parts individually, so far i came up with this list
NV3500 2WD
Pilot Bearing/Bushing
Flywheel + Ring Gear
Clutch Master Cylinder
Slave Master Cylinder
Clutch Pedal Assyembly
New Starter For Manual
Reprogrammed ECU
Clutch Hydraulic Lines
What else would i need? also can i grab the parts off a 4wd truck (except the Tranny) ?
NV3500 2WD
Reprogrammed ECU
Check the driveshaft lengths. They may be different.
Tranny and driveshaft could not come from a 4wd truck, but the rest should be fine.
scott240
24
03-27-2011 03:13 PM
lowloudnproud1
06-13-2010 01:34 AM
Al3x
03-07-2010 09:49 PM
