Did I time my engine right?
Old Feb 26, 2012 | 01:59 PM
kuojo's Avatar
kuojo is on a distinguished road
Default Did I time my engine right?
Ok so I have been working on a 95 blazer for awhile now and came to the conclusion that a sensor in the distributor was bad (EDI timing) I replaced the sensor but I didn't drop in the distributor right the first time due to a mistake I made. I had to reset the engine to TDC and I used the 1st cylinder but it still won't start. When I was checking for compression I could feel air on my finger but I couldn't tell if it was going in to the engine or out from the spark plug 1 hole. Any help or tips would be greatly appreciated. Thanks
Old Mar 5, 2012 | 10:26 AM
kuojo's Avatar
Ok so after some research I got the timing correct but it won't start. It gets close and backfires. It will turn over for a sec but then it cuts out. Any ideas
chris015
Nov 23, 2012 04:57 PM
BlazinMike89
Feb 27, 2009 12:26 AM
ant2297
Sep 14, 2008 03:40 PM
redpeppers
Apr 7, 2007 04:55 AM
jdpilot
Mar 28, 2006 10:52 PM
