died and wont start
Old Sep 17, 2013 | 04:18 PM
TrainChaser22's Avatar
TrainChaser22 is on a distinguished road
Default died and wont start
I have a 1999 blazer 2 door 4wd i tried to go somewhere but i only made it down the street a block it died and i have not been able to get it going again i just had the fuel pump replaced my neighbor suggested i replace the TPS so i did that and it still wont start if someone could help me with some other things i might try that would be great thanks
i should have added it does crank it just wont catch and start
Old Sep 17, 2013 | 04:27 PM
First step is check fuel pressure and leakdown. Most auto parts stores rent/loan/sell pressure testers. Let us know when you have one available and we can explain how to use it.
Old Sep 17, 2013 | 06:11 PM
Diaita's Avatar
Sounds like an ignition switch issue too. $.02
Old Sep 19, 2013 | 09:47 PM
Emzyt's Avatar
Emzyt is on a distinguished road
I have the same issue, driving down highway just died restarted within 1 second on its own then died again and will not restart. Towed it home no fire at plugs. Have change crank sensor, coil, pick up coil in dist. rotor button, distr. cap, (previous items new) brain from a salvage yard. No help. Oh I was previously having issues with starting cold start only had to crank a couple of times. Once warm would fire right up. I cleaned the EGR Valve the day before this happened and that fixed the cold start issue. There was still a dead miss and a hesitation at take off (sometimes). Anyone have any ideas please. Thanks
Old Sep 20, 2013 | 04:17 AM
Dobe Rottie Gang's Avatar
Dobe Rottie Gang is on a distinguished road
Have you done a fuel pressure test on it to make sure the pump is working correctly?
Old Sep 20, 2013 | 03:40 PM
Emzyt, You may have created more problems by replacing the crankshaft positon sensor and the PCM. When the crankshaft position sensor or timing cover are moved, removed, replaced, or disturbed in any way, the crankshaft position sensor relearn MUST be performed. If/when the PCM is replaced, it MUST be flashed, (reprogrammed) to your VIN, AND the crankshaft position sensor relearn MUST be performed. The camshaft position sensor, (in the distributor) does not affect ignition and can not cause a no-start condition, (If you unplug it, the engine will still start & run).
What DTC's did you retrieve, and what order were they retrieved in? As mentioned, check fuel pressure and leakdown. The symptoms you're describing are classic for low fuel pressure.
Old Sep 20, 2013 | 06:42 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
I had the same start stall problem on a 01 Durango because the pcm wasn't flashed right. I had it reflashed and cured all my problems
Old Sep 21, 2013 | 08:06 PM
Emzyt's Avatar
here is the update the brand new coil pick up (inside the distributor) was bad from the start. Finally checked this part with an OHM meter and returned it and exchanged for another one and voila MY TRUCK IS UP AND RUNNING. Life is Good. Thank you for all of your assistance.
Old Sep 21, 2013 | 08:43 PM
Emzyt, Don't hold your breath. The camshaft position sensor is used for detecting and identifying cylinder misfire only, it does not, and can not, affect engine performance. You still need to check, (& adjust if necessary), camshaft retard so the data from the sensor can be used accurately by the PCM.
The replacement PCM is using crankshaft position sensor data from the last relearn that was done to the PCM, (which was in the donor vehicle). Crankshaft position sensor data is used for ignition timing, injector timing, injector pulse width, fuel mixture, etc etc etc. If the data is incorrect, the engine will not run properly. The relearn must be done because the crank sensor and PCM were replaced. Reinstalling the original PCM will require the relearn because the crank sensor was replaced.
DCFluX
Aug 25, 2013 02:31 AM
zstudna
Oct 15, 2012 07:19 PM
95s10
Jan 21, 2011 10:08 AM
dlihcsnatas
Sep 14, 2010 10:22 AM
n.kognitoh
Jun 14, 2010 01:22 PM
