differentiate what transfer case I have
Old Jul 19, 2014 | 08:48 PM
Beatrice79's Avatar
Beatrice79 is on a distinguished road
Default differentiate what transfer case I have
Hey guys,
I have a 1979 blazer, and I'm trying to figure out which transfer case I have. I have a saginaw 3 speed manual transmission, but both the np205 and dana20 transfer case were used that year. How can I figure out which one I have?
Old Jul 22, 2014 | 12:19 PM
abig84's Avatar
the np205 should have a plate on the backside of it saying what it is if its still there, i think most dana's did the same thing. if you can take a picture of it and post it im sure someone will know it is. i know what a 205 looks like, not sure on the dana transfer cases though
Old Jul 29, 2014 | 08:55 PM
Tranzman's Avatar
Tranzman is on a distinguished road
NP205 t-case is a chain drive, big ole cast iron thing. Mostly used with Automatics. it has 2 6-bolt covers on the back side of it. one has the output shaft coming out of it. the other is just a cover. i also has a single shift lever on it.
Dana 20 is a smaller gear drive cast iron unit. it has a single 4 bolt cover on the backside. it has two shift rails that attach to a single plate at the shifter. Mostly used with the stick shifts
Old Jul 31, 2014 | 07:07 PM
Beatrice79's Avatar
Default found it
After a solid amount of brake cleaner fluid once I had pulled off the transfer case, I found the casting number. It was a NP205. Thanks guys!
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
soky25
Mar 12, 2010 04:52 AM
jayfire
Oct 4, 2009 11:10 PM
skynyrdcat
Mar 1, 2009 05:59 PM
