Direction of Rotation
Old Sep 14, 2015 | 02:46 PM
reevesjo's Avatar
reevesjo is on a distinguished road
Default Direction of Rotation
2002 Blazer 4WD, 4.3L Sorry, I forgot to look before I started the tear down. After looking at my "Trailblazer" which rotates CCW when standing in front, looking back, I am assuming my "Blazer" is the same. I want to turn the crankshaft by hand with a wrench to bring it to Top Dead Center before I remove the distributor? Please tell me if this is right. Also, if this is proper, the pulley bolt is surely left hand threads?
Old Sep 15, 2015 | 11:54 AM
reevesjo's Avatar
Default Cockwise
I found out myself. Had to remove the fan assembly to get to the crankshaft pulley. I started by turning it Clockwise while facing it. I watched the distributor rotate Clockwise also. Now I'm ready to remove the distributor, then the lower intake manifold, then the RH head to inspect the #4 cyl valves. I will probably be back.
edphot2009
Tires and Wheels
Apr 21, 2011 01:01 PM
Kirk-NJ
Feb 24, 2010 03:25 AM
blZrRooK
Aug 27, 2009 02:22 AM
S10Blazer
Sep 1, 2008 08:41 PM
raviz
Nov 21, 2006 09:54 AM
