Distributor installation
Old Aug 22, 2017 | 10:26 AM
Jared9519's Avatar
Jared9519 is on a distinguished road
Default Distributor installation
Hi, I have a 2003 blazer 4dr while trying to replace a spark plug wire my distributor mounting points snapped. I went and bought a new distributor and cannot install it timed properly. I've tried every technique and tip I've found online but I just can't get it to line up with the 6 when cylinder 1 is at tdc. I'll have every notch and mark lined up properly but when I drop it in there it won't line up with the 6. Any help is appreciated
Old Aug 22, 2017 | 11:05 AM
See if this is of any help
https://www.2carpros.com/questions/2...et-s-10-timing
I've always just made note of the direction the rotor was facing when I removed it and made sure to install it with the rotor pointing the same direction upon reinstallation. Most run into issues with this if they remove the distributor and then turn the motor over without it installed... That's when the finding #1 TDC on the compression stroke is necessary...
Old Aug 22, 2017 | 01:48 PM
LesMyer's Avatar
In my experience, it doesn't line up exactly when dropping in the distributor. If no SES light and it runs, then you've got it on the right tooth (no doubts). But you really should check cam sensor retard when done if you want optimal performance.
You may have to turn the oil pump shaft with a huge screwdriver to get the distributor to drop down all the way where you want it. Don't forget about the helical gears will turn rotor as you drop it in.
Old Aug 24, 2017 | 06:07 PM
newguy's Avatar
That s what I use, a long flathead screwdriver
Old Aug 24, 2017 | 06:10 PM
newguy's Avatar
This helped me.
genso
Dec 1, 2016 10:13 PM
racsan
Feb 10, 2013 08:01 PM
Klturi421
Aug 5, 2012 07:59 PM
ivannj
Feb 17, 2006 03:36 AM
pengifyd
Nov 15, 2004 11:01 AM
